'94 F-150 electrical system question for HLF
Ford f 150 would be negative ground eletrical system.
Be careful! I understand what you meant, but asking what asked will get you the wrong information. Almost every modern vehicle has a negative ground electrical system
However, what I believe you are asking about is whether the headlights are positive-side switched or negative-side switched. Your 1994 F-150 has positive-side switched headlights, and has a negative ground electrical system.
jdarland
