tacomabanga19861986
this is my pov setup, i will take pic's of my switchbox and what knot tommrow
setup goes as this
grill = whelen strobes (red)
side markers - whelen haw's both on whelen power supply (clear)
dash = galls dashlight w/ federal signal ricochet power supply (red/clear)
side windows = whelen dashking 2000 6&1/2'' wide strobes (red)
back window = tomar rect 37 strobes (red)
tool box = code 3 led's (red)
tail lights = whelen haw strobes
tool box top = code 3 traffic advisor
will add strobes to either reverse lights or brake lights later
i have dash light on its on switch
grill lights and haw in front are wired together on whelen 75w 4 output power supply, and are wired on there own switch
both side window lights wired to there own switch
back window lights wired to there own switch
toolbox lights come on with main switch
1 switch turns on main power to powersupplys
i have a federal signal 6 switchbox wired with a relay off a switch wired to the acc wire to turn on switchbox, acc switch fused, relay wire fused, and each switch output fused @ 20amp
its my first pov install so i guess it came out ok
let me know what you think, and what would you change or move around as im out of ideas, i have 2 haw's to put in either revers, or tail lights
um, whelen power supply has action flash pattern, does quad side to side on front lights
dash light is on random back n forth pattern
side dashkings set to the 3 bursts and quad flash pattern they have built in (dunno what its called) might be comet flash
back window same pattern as whelen supply
tool box set to random as each light doesn't flash at same speed so random looked better
setup goes as this
