AuroraBorealis
Sirenman said:The cracking was caused by the fact that the housing was not annealed during the spinning process, thus causing stress to build up in the metal. The cracks are simply the stress relieving itself causing what are called stress cracks. You can weld them although that is a difficult process, but they will only crack again somewhere else. There is no fix for this problem other than replacing the housing.
John Dorgan
