John Smith
I'll be up-fitting a used car to be used as an admin/travel vehicle for our Officers. It'll be an 07-14 Tahoe civilian model.
I was planning on putting a dual SoundOff nFORCE dash light in the windshield, and a pair of mPOWER 3" in each fog light housing (So two nFORCE modules, 4 mPOWER modules). All of the lights will be dual color, either red or blue and white. I will be using a simple Galls 9 switch panel that energizes a wire with a switch.
The problem I'm having is that the SoundOff lights don't offer an option to steady burn red or white depending on wiring inputs. So the module can either steady white, or steady color, it can never have one switch steady white, and another switch steady color. And I don't mean at the same time, but even at different times, it can't do it. So I get to choose steady color, or steady white. Well I wanted a takedown function and a cruise function, but cannot have both with SoundOff.
Do Whelen or FedSig offer similar style/size/brightness, dual color, light that allows both steady color and steady white depending on a +12v input? Again, not at the same time, but different times for takedown and cruise.
Note, I don't want an elaborate controller (ie BluePRINT), I will be using the simple Galls controller.
For those that care, side lighting will have an under-mirror dual color pod on each side, possibly another nFORCE module in one of the windows but I doubt it. Rear lighting will have an 8 head nFORCE traffic controller in the rear window. The car will also have the SoundOff HLF/TLF, and a SoundOff 200 series siren.
