Airhorn Only"Horn Ring"
Gary599
19
Florida
I have a Touch Master Delta. I do have my Factory Horn. If I place the Touch Master into stage 3, I can use my horn ring to use the siren. My question, and I dont think its possible, I would like to actvate the air horn using the horn ring in place of the factory horn. Is that possible?
Gary
Apr 28, 2012
1,042
Knox County, ME
You can do a relay set up
Gary599
19
Florida
Ok, that is above my pay grade, but even if I did have a relay, I don't see anything in the manual that would sound the airhorn on the press of the horn ring.
Gary599
19
Florida
Sorry I do see a relay in the manual but does that relay allow just the air horn. Currently have grabbed the horning wires from wiring harness.
I have a Dodge Charger Pursuit........ And I wired in the back of the touchmaster to the two wires from the wiring harness without the use of a relay.
ur20v
571
Northern Virginia
The horn ring circuit was never intended to replace the vehicle's horn, it was just a convenient "remote control" for siren features when you need eyes on the road and both hands on the wheel. I came to this conclusion after seeking a way to replace one of my vehicles' horns with the airhorn tone of a Touchmaster. That being said, you can modify one of these sirens to function this way, but it would take some work coupled with knowledge and skill. An easier solution is a relatively more modern siren like a Whelen HHS2200 or similar. Very inexpensive and easily programmed and will do what you need it to.
Gary599
19
Florida
Sorry for the late reply. I need lighting control, so I would rather get a siren that can provide airhorn on the steering wheel as well as being able to control some lights.
CHIEFOPS
1,533
NYC
Wait a minute- why can't the siren be configured to default on power-up (ignition) to HORN RING mode with the selected tone being AH instead of SIREN, independent of the lighting? If the Touchmaster can't the SmartSiren can, and I'm fairly certain the Unitrol 80/480 can too.
bfpd108
