Another Federal Beacon question
gpd132
Junior Member
56
Gulfport, MS
Could someone explain the different types of federal beacons? I got a model 17 but I see models 173, 174, 175, 176 etc.
It seems that some beacons have more lights than others and some beacons have tall skirts. I can't seem to match model numbers to characteristics of each model from pics i've seen.
Thanks,
Mike...
Mike,
Model 17 (the first one produced) has 2 sealed beam bulbs mouned to a tube like bulb holder, rotates 360'.
model 173 three sealed beams, rotates 360'.
model 174 super beacon ray 4 bulbs all turn on at same time, light oscilates 95' and then back the other way.
may also contain a cruise light from hawaii pd.
model 175 (hill light) 4 bulbs, 1 mounted at 45' upwards, 1 mounted at 15' downward, othe 2 bulbs face out as normal, switching is 2x2.
model 175H nypd special 1 bulb mounted up at 15' one bulb down at 15' other two are normal, 2x2 switching.
model 176 4 bulbs, rotates 360' all bulbs usualy light at same time.
Earlier model 17s had smaller domes with slanted sides. I believe the smaller domes were phased out in the late 1960s :?: . The larger, more straight sided dome was introduced when the model 175 came out.
Actually, it was early model 17 and 173's that had the smaller dome. The small dome Beacon Rays ended in 1968, which is also when Federal changed the serial numbers to a "2R" prefix. 174's made for Hawaii also contained a cruise light. Finding an original 174 with the cruise light is extremely rare.
Circa 1974:4.jpg[/attachment:39yasmvi]5.jpg[/attachment:39yasmvi]6.jpg[/attachment:39yasmvi]
Also note that even though they each have 4 bulbs, the 175 and 176 rotate at different speeds. 175 is about 40 RPM or 80 FPM from the horizontal beams, 176 is 25 RPM or 100-105 FPM.
kb1sph
