Well my 1986 Ford F 250 flatbed is just about ready to hit the road. Before I list the warning equipment first - why. This truck is used for a buisness that plans, set up and working at special events. The warning equipment is used for attention gathering, traffic control, event safety and some winter snow/ice work. Very little of this work will be on the public roadways. The green and noise maker are capible of being turned off under the hood to meet any legal concerns as needed
Now the warning systems.
Front
4 sinc amber led hide a ways. 2 in the turn signals and 2 in a pair of driving lights. No name unit but not that bad. worst part is only 1 alternating patteren.
SVP Hotshot on dashboard mount either amber or green with mirror.
Roof
Federal Signal All Light Streethawk. White base. Center rotor is green, standard outboard rotators are amber. Inboard rotors were removed. Lower pods are all clear work lights except center rear which will be amber currantly in red.
Rear
Whelen oval strobes in amber in alternating triple flash.
A 8 head Whelen Traffice bar is mounted on a removable stand and it can sit on the lid of a cross bed tool box.
Sides
On the underside of the flatbed behind the cab is a Lin 4 split amber/clear mounted vertical (just looked good that way).
A siren is mounted on the truck. S & W Magumun. This is used mostly for the PA. I would replace this if I could find a used air horn PA type unit.
The green lights were installed with the idea the at one of our special events anyone else using lights would be using amber and the green light s would be used as a lcating beacon if needed. As soon as the plates come in and it's inspected I will post pictures.
Support Services
Front
Roof
Rear
Sides
Support Services
