Axixtech SV
C420sailor
502
Virginia, USA
Two Stealth Visor questions for y'all:
1) Can LED modules be moved around? In other words, if I get a RRWRR can I easily make it RRRWR?
2) Do the Ford Explorer mounting brackets fit the earlier Explorers (circa 1998)? Or do I need to go with universal mounts?
Thanks!
May 24, 2010
1,627
PG County, MD
Thanks!
1) With the exception of takedowns (LX4 Modules), yes you can move them around.
2) Not sure on the Explorer bracket, as I haven't had any experience installing one in a pre-2000 model.
C420sailor
502
Virginia, USA
Thanks for the info! I'm pretty sure the 2000 is essentially the same as the 98. Did you use Explorer specific brackets in the 2000?
ERM
720
Omaha, NE
drew7262
