Steve0625
Just a quick question or two. I just received a used set of TRI LAW's by Axixtech. They didn't come with an install sheet and I haven't been able to find one via Google.
The flasher unit is labelled:
YELLOW - For Synch & Flash Patterns
WHITE - For Simultaneous or Alternating Flash (for multi units)
Do I use yellow for pattern change, and if so, do I ground it or give it +12vdc?
If I am not synching with anything else, I should just tape off white, right?
Thanks in advance. Don't want to trash these things before I get to use them.
