Bigcat's Surplus Stuff
bigcat
641
Hartford County, CT
Shipping in the CONUS. Not shipping internationally right now.
I use PayPal.
Two Code 3 LED-X light heads on MX7000 brackets. Set to steady burn but has a few un-synced flash patterns. Both Blue. Brackets have room for one more LED-X on each. $35 for the pair shipped.
One Code 3 LED-X WHITE on an excalibur or 2100 bracket. Set to steady burn but has a few un-synced flash patterns. $20 shipped. Will bundle with LED-X above for better price.
Ups690 six outlet Strobe power supply with new wire pigtail purchased on eBay. $40 shipped.
NIB Whelen Pierce Alert. Only issue is the plastic hooks to secure the motor are broken off (common problem). Motor can be secured by wrapping a couple pieces of rigid wire around it (that's how my used one is). Never tested. Comes with some mounting hardware. $40 shipped
Whelen 9M flasher. Whelen says halogen flasher but the flash patterns are all fast for halogen. Works great on LEDs. Powers 4 lightheads, steady burn override on one pair of lightheads. 4 different flash patterns. Comes with three wire harnesses as pictured. Input harness for control is usually the Lightbar cable. Used, tested. $22 shipped.
SOLD
Svp sa-450 siren. 100 watt. Used, tested.
Blue sea fuse panel.
Sound off headlight and tail light flashers.
Whelen 295HFSM1.
Switch panel with Carling switches. Perfect setup to control a Carson SC-1012.
Havis switch panel with contour switches SPST and cigar outlets.
9m4s power supply
7d9_z28
3,048
West Michigan
GSPS629
