Bought a 2007 F150 Lariat, Ideas
TNFF412N
387
San Antonio, Texas
The equipment i have is as follows
4 lin4s that are going in the grill
headlight flasher
single avernger dash or headliner
6 strobes for tailights
licence plate bracket with 2 tir3
and a microman 2 for back window
kenwood radio in center console cubby
and all run off a Whelen HHS2200
What i want to add is a flasher for the foglights
and an inner edge for the windsheild
right now nothing on the sides, once i figure out if i can get some vertex on the running boards .
other then that i think im good
What do yall think and what should i do or not do?
Right now im not sure i want to drill the headlight housings, so that is out of the question for now anyone know where the horn ring can be hooked up to make the hf work i guess i can tag it at the horn in the grill !!!!
Your going to have to add more lighting the front than just a single avenger. I would most certainly go with the inner edge, also go with the vertexs they do look really good on the running board but.
Not sure what color your LIN4's will be, but stick to a solid flash pattern
Personally for the front I'd go with 2 TIR6's/LINZ6's in the grill, Dual viper or dual avenger behind the RVM. Or do the inner edge.
Sounds like you have everything else pretty well covered.
well all the leds are RED and solid and not split pattern, i miss spoke when i said 6 in the tail lights i ment i have six but am doing 4 to the rear and will not drill the front corners.
I am getting the frop in insert console from havis , and will be getting an inner edge , anybody have one for sale, or can get me in touch with someone who does...
If you have 2 open outlets on your power supply and you can have clear to the front I would put HAW in the fog lights. I have them in my F-150 and they look really good.
Ziva
