Don't know the make and model. No tags.
S stansdds Member May 25, 2010 3,540 U.S.A., Virginia Sep 21, 2013 #2 Sireno MC-2 would be my guess. These look to have color lenses instead of colored sealed beam bulbs, I think that makes these worth a bit more.
dmathieu Lifetime VIP Donor May 20, 2010 8,783 S.W. New Hampshire, USA Sep 21, 2013 #3 I'm thinking North American Signal, due to the bulb retention system.
marslights_IL Member May 28, 2012 80 IL Sep 21, 2013 #4 When I get a chance I will open them up and post a pic, if that helps.
dmathieu Lifetime VIP Donor May 20, 2010 8,783 S.W. New Hampshire, USA Sep 21, 2013 #5 I can see the clamps that are holding the bulbs in the housings. The Sireno use a metal clip that inserts into the housing to hold the bulb. I'm also thinking that the bulbs are PAR 36 extended lens sealed beam bulbs. The extended lenses are actually part of the bulb. Last edited by a moderator: Sep 21, 2013
JennyCop Member Jan 19, 2012 2,021 Sunny Arizona Sep 21, 2013 #6 I agree with Dan, these are North American Signal Can lights, I had a pair just like them. The bulbs are extended par 36 as Dan said.
marslights_IL Member May 28, 2012 80 IL Sep 21, 2013 #7 Thanks all. What would be the approximate value?
S stansdds Member May 25, 2010 3,540 U.S.A., Virginia Sep 22, 2013 #8 dmathieu said: I'm thinking North American Signal, due to the bulb retention system. Click to expand... Yep, my bad.
I INSTLR60 Member Feb 23, 2012 509 WISCONSIN DELLS, WI. Sep 22, 2013 #9 marslights said: Thanks all. What would be the approximate value? Click to expand... north American, in wheeling, ill currently make these,so they are still current.
dmathieu Lifetime VIP Donor May 20, 2010 8,783 S.W. New Hampshire, USA Sep 22, 2013 #10 Here's the Sireno.
dmathieu Lifetime VIP Donor May 20, 2010 8,783 S.W. New Hampshire, USA Sep 22, 2013 #11 Some North American on a bar.
Captain4164 Member May 3, 2012 952 California Sep 23, 2013 #12 dmathieu said: Here's the Sireno. Click to expand... I have ones like those, going on my next project. Nice to know what they are
