Alright ya'll, I am stumped. I have a Carson 1012 hooked up to a SOS 100H speaker. When I wired up everything, all worked with the exception of the manual option. The next day I re-tested everything and it worked. I let the mechanical tone ramp down before testing other tones. After it ramped down and turned off (as normal), I tried to use it again and it wouldn't work. The wiring, fuses, connections are all good. The speaker is 6 months old so I can't imagine it would have died, but I have not tested it yet. Any suggestions or things I can double check other than testing the speaker? You can hear all the tones when you put your ear to the siren box, but yet again the manual option doesn't work. HELP!
Note: The two light switches work properly.
Thanks,
Andrew
Thanks,
Andrew
