Changing the pattern on the Valor lightbar?
mcpd2025
1,557
Maryland, USA
I got assigned a marked car with the Valor lightbar on it. Fantastic lightbar, worlds apart from my first cruiser with a Code 3 LP6000 lightbar! The flash pattern that is on all of our cruisers is rather seizure inducing. I'd like to change the pattern on mine, but I cannot figure out how in the world to do it. Is this something that an end user can do, or do I need to take it up to our county shop and beg/borrow/bribe a tech to change it for me?
C17LVFD
Harrisburg, PA
I believe the programming for the valor is done within the SSP. As I recall the SSP acts as the serial interface box or SIB for the Valor.
If you can make friends with one of the install techs at the MontCo yard, maybe they can get you squared away.
I believe the software maybe on FS's website so that maybe another route.
Best of luck!
Seth
redbudjoe
187
Nashville, TN
I’ve just got ahold of a valor, so I’m learning about it and FedSig. Ive spoken to FedSig about it a few times o er the phone. If you have the SSP 2000 or 3000, you can download their software from the website to program the bar. From my understanding, you connect the siren brain to your computer, and you can customize the lightbar options. It does take the place of the serial interface, and is all run with the Cat5 data cables. If you can find the siren brain, and download their software you shouldn’t have too much problem figuring out how to change the pattern. But safe bet is to have a shop do it, if it’s an option for you. Best of luck!
idk
