FusionWolf
I recently bought 6 cobra t6 dummy heads from Nic at FEVER. These lights are going to be mounted on my roof rack on my Xterra to essentially make a low profile cobra 600.
I want to tap into the 2 end lights to make them act as aux brake lights. But due to overheating and the blinding factor, I need these lights dimmer. They will not function as running lights just brake lights. Now I know I need a resistor to dim these, but what size?
I tried a 1w 100ohm but that only allowed half the light head to activate. But was the desired brightness a 1w 10ohm didn't do anything and got way to hot. What do you guys recommend. Want to steady burn at maybe 60-70% the standard brightness
