Newton15
Ive got a deluxe controller for the code 3 arrowstiks and when I hooked it up it will only steady burn two bulbs in the stik, no flashing, or directional signals, and when I change the selector on the controller the two bulbs that are lit will change. I tried it both on a stik in a MX7000 and another stik, same result on both units. Both stiks work correctly with the standard controller I had, the deluxe controller worked fine with the MX7000 about a year or so ago. Any ideas whats happening, I hooked up the wires according to the directions on the controller. Is the controller shot or did I connect something incorrectly? any input is appreciated.
Thanks Ryne
Thanks Ryne
