What's the best way to ground a Code 3 MX 7000 lightbar. I've got one end grounded to the vehicle, where within the lightbar is the best place/area? Thanks
The grounding cable in your control cable SHOULD be connected to the extruded aluminum frame that the bar is built on.What's the best way to ground a Code 3 MX 7000 lightbar. I've got one end grounded to the vehicle, where within the lightbar is the best place/area? Thanks
100% agreed, unless you are running your cable down the windshield, and are willing to cut your jacketing back that far to get the ground cable out and to the batterynever run a cable all the way back to the battery... thats alot of added resistance...
unless its one of those whelen bars that specifies too.
