Code 3 MX 7000 LAPD Style restored and rebuild
SaschaUE
188
Germany, Hamburg
another projekt ended.
a code 3 MX 7000 LAPD style lightbar.
all black metal parts are new black powder coated. all parts are polished. the upper deck domes are wet sanded and polished.
the lower deck domes are new.
you can use the flasher with two different flash pattern or as steady burn.
here some pic´s:
denko3
866
SLOVENIA,EUROPE
great restoring! :)
i am waiting a few parts and i will build my LAPD MX too,can't wait.
just that i will have rear seperated amber flasher on each end of the bar and 6-arrowstick seperated.
which bulbs are in CAL steady burns front lights? how many Watts were original?
did you cut the center cylinder red and blue filters apart or they were original cut down?
were code3 manufacturing speacial order for LAPD for those 1/4 cylinder filter?
does someone knows which configuration have LAPD Excalibur bar?
can you post some video?
again Great lightbar!
fireball3
864
Lyon, France
very good project! ... super good work!
I know this question comes up often and many ways to renovate the lenses one knows, but when I see the result of your work, looks brand new!
Sascha, what method you used to renovate the domes?...I'm speechless :eek:
/Cyril
Abacus
432
Sydney Australia
This is great.
Can you explain how you wired up the code3 flasher? Did you run a constant 12 volt to the input and separate wires for all the switching options. I recall that the instructions recommend a jumper between the power and the first flash pattern.
For any other mx7000 engineers how was it originally wired ex factory?
SaschaUE
188
Germany, Hamburg
ok i will try to answer all your questions.
- bulbs steady burn: i dont know wich is original. i build in code 3 flasher bulbs so i can use the 710 flasher.
- i use wet sandig paper to renovate the domes. grain size: 1000, 1500 and 2000. after that i polished all with nanotec polish. first polishing with hands and then with a polish machine
- yes i have connected a constand 12+ to the flasher. and for every flash mode and the steady burn another 12+ on a switch. i connected 5 cables on the flasher. ( 12+, ground, mode 1, mode 2 and steady )
here´s a wiring picture
Uman18
423
Port Hueneme, CA
denko3 said:
great restoring! :)
I think I might have 1/4 cylinders and many filters from MX bars.
woobatu
