Wanted Code 3 torus housings
Elmira, ny
Hey all,
Currently looking for 2 of the housings for my 2 code 3 torus led heads I got from Mr. Phoenix_rising a couple weeks ago if anyone has any.
I would like to in the future use them in an mx project bar I wanna do :)
Thanks muchly :)
Reactions: Dave F
CD3
411
USA, CA
Hey all,
Thanks muchly :)
When you refer to Torus that was the LED technology we started using in 2011, what exactly is the light you need the housing for, can you get a picture of your LED?
CD3
411
USA, CA
OK, That is a Narrowstick module and believe it or not we called it a surface mount, the bezel was a surface mount but you had to cut the vehicle body to fit the light. OK, it will not fit in the lower deck of the MX as it is. Now I ve done it but only in an emergency and is time consuming, you can carefully remove all that potting and take out the board and LED head. Then find the correct lower mount. It looks to be blue in the photo, is that correct? I have those which we called 3UP for the lightbar, or 4UP & 6UPs. I have a bunch of blue 3UP LED light engines and the Lightbar lens in spot or flood and the LED driver boards, but I do not have the mounts. I do have the bezel for that LED module you have but it will not help you in mounting.
Elmira, ny
Its blue but more along the way of teal blue (both are that way)
I was gonna get an "L" strip at one of the local hardware shops and make my own brackets, but would like to find the housings for these (if one is available for it)
jkelly
