Cuda TriOptic SignalMaster wired to Whelen TACTLD1?
FDNY 10-75
457
NY
I have a Cuda TriOptic SignalMaster with the original controller, I recently purchased a Whelen TACTLD1 and was wondering if I could use them together? Thanks
Should be able to. Red from the SM will go to the white of the controller. You'll have to trial/error the other individual light wires.
I've done it reversed (Whelen TA on a SS2000SM). Worked fine.
The wirng for a standard Signalmaster left to right is:
white
brown
green
orange
violet
grey
yellow
blue
Red - power
The standard wiring for a Whelen TA is:
brown
red
orange
yellow
green
blue
violet
grey
white - power
Not entirely off, but I did use a TACTLD1 with a Vector Signalmaster and it worked fine.
But now with the Cap on my truck, the Signalmaster would be blocked, so I removed it and
mounted it on the back cap door. Now the cable is shorter, so I wired it to the 2 wire control
from an InnerEdge (8 lamp TA with End Flasher board)
SWERVIE
