Custom 12 head dominator flasher ideas
wilsonbr90
1,427
Corning, New York
So I'm in the process of making a custom 12 head dominator. Will feature 6 linear3 heads and 6 tir3 heads all on a single stick. Will be 2 color for my application. Will be used as a rear arrow and warning light so patterns don't have to be crazy fast. Will be amber arrow(6 heads)
And warning color for the rest.
Now to the fun part, finding a flasher/ Flasher's that can be used for arrow and warning lighting. I'm not overly looking for an arrow controller because I would hope to keep the multiconductor to a minimum length. Plus I have 2 wire arrow control on my light controller.
It would be nice to use the flasher in an interior bar, but those aren't readily accessible.
Anyone have any ideas?
7d9_z28
3,048
West Michigan
I'll bet member ERM could hook you up
emtanderson51
3,795
USA Massachusetts
I would remote mount a Liberty LC I/O board. TA override and independent control of every pair of lights. That would be outstanding.
got_yogurt
BC, Canada
And you can pick them up cheaper these days than most flashers
RES347CUE
542
NASSAU COUNTY N.Y.
Im not too sure on the flasher question but i think that is a great idea and look forward to seeing a video of it complete
good luck
wilsonbr90
1,427
Corning, New York
Was hoping to utilize my 2 wire arrow control which the liberty IO would let me do. Trying to eliminate the multi conductor runs to a minimum. I will definitely post some pics when I'm finished.
OVERKILL
448
hamilton ontario canada
ive done a few of these. I just used the internal flasher and made a pigtail that went between the harness inside to tie into the ground and used the scan lock wire to power 4 linz6 heads as end flashers. these are the only pics I have
woobatu
