I wanted a new mini bar for my plow truck. After looking at a few options, the price i was gonna end up paying for a mini bar with no options, i could get a full sized, full loaded liberty, for not much more.
So that's what i did. Went with the full sized liberty.
I started out with a 48" Liberty SX. It was Red/blue with an amber TA
I wanted to use this as a "throw light" that i can use in whatever plow truck I'm assigned to. The "Dual Purpose" part is that im also FF/EMT and wanted something to respond to calls with, if i had to.
I cut the frame of the Libby down to 28" and moved all of the rear amber modules around. I have it set up to run blue/white to front for Fire/Ems responses, and have amber/red for plowing. I added 4 LR11s to use as work lights.
The front two corner modules are blue LIN12 extended corners. Im currently depopulating them to 6, and adding 6 amber LEDs. the idea here is to essentially create "DUO" heads, that will run blue OR amber. Wilson is doing the conversion.
I have it all wired to a Brooking Industries 6-switch box, and have that wired to a 12V Cigarette plug. (ive ran the entire bar and switch box off of a cordless drill battery for hours, so im not concerned with current draw.)
The lenses have been wet sanded, polished, and turned out pretty good.
For the bar itself i have (4) 200lb pull magnets. Still not sure if i wanna do 3 magnets in-line with the bar, or do 4 on all 4 corners? What do you think?
this switch box is set up as follows:
1: Ambers
2: Flashing TDs and Allys, also single rear amber pod
3: Rear Red
4: Front Blue
5: Work lights
6: Cruise lights.
After the cut, there's enough left to build another mini Liberty, if anyone's interested.
Here are some pics and a current video.
Custom Whelen Liberty: http://youtu.be/683q9zAeqxI
1: Ambers
3: Rear Red
4: Front Blue
5: Work lights
6: Cruise lights.
