dmitry103
Because I'm not a fan of Chinese knock-off bike lights, I wanted to give my bike some zest and installed two Whelen LIN4s. The area I live in has many hills, valleys, sharp curves etc, thus I'd like to be seen before getting accidentally hit Anyways, I installed the lights and faced a problem of powering them up, adding switches etc. Everything was resolved with an electrical box (shallow one), plastic faceplate of the same size, two on-off switches with light indicators and a can of flat black spray paint.
Here we go...
These three items cost me $2.96 at the local Home Depot. Talk about "the economy project"
Two 3/4" holes pre-drilled, faceplate spray painted, switches inserted.
The rear R/W LIN4 mounted to cut-to-size siren bracket. The front light mounted the same way.
The switchbox assembled. Two "I" shaped lines have been cut in the base of the box to allow the clamp to secure everything to the frame. Everything being powered by 9 volt battery (located inside the box)
Front R/W set to steady WHITE and flashing RED. Read R/W set to random flash.
What do you think?
Here we go...
What do you think?
