ProPatriaNeverPassAFault
Silver Supporter
Ok got a surplus CPD Legend off the bay for cheap. Always a roll of the dice there!
Bar works well lest for the passenger side t/d not lighting. No biggie. Brake/turn signals don't work as I don't have a CPD serial controller. No biggie.
The biggie is that the inside driver's side board appears to be dead! Doesn't light up. Neither the LED modules or the halogen t/d. I'll check the connection between the board and the I/O board and see if that helps.
So if it's a buggered i/o board, how easy are these to come across to replace? I'll contact the seller and ask about spare parts or look around. Neither the i/o board or ROC panel have to be CPD. Finding those would complicate things. Would probably just remove and store CPD parts and overhaul the bar to be a standard b/b Legend or r/b, if need be. Wouldn't be a high priority project, that's for sure. Kinda wanted a CPD bar, but it is what it is.
Any suggestions of what might be going on and posdible fixes besides replacing panels and boards? Does it sound like the i/o board or the ROC panel? Would an i/o board from an Arjent S2 work? They seem to be a dime a dozen and for what it's worth, more or less the same bar.
EDIT: Checked the connection to the i/o board. No issues. Didn't tear the entire bar apart. I/o board looks like it's in rough enough shape due to heat. I'd hope that this is a connection issue, so taking the bar apart is in order.
Still looking for suggestions, though. I'd love to get this bar working, but given that it's a CPD bar, finding parts is going to be a major PITA! Also $$$!
Also, there's a second black cable from the bar. Has 20 ga red, black and green wires. Guessing that they're for the brake lights.
