empire5150
Selling this Dietz 2-11 beacon I just picked up. Technically it works, but is a project. Issues; 1, The sheet metal bracket on the bottom of the motor has a broken back lip which holds one side of the motor to the base. So someone put a nut and bolt through one corner to secure it. This fix does work and secures it. 2, Originally the bulbs did not light up but as I let it run they slowly (1 at a time) lit up and seem to be ok now with 1 small "dead spot" while spinning. 3, the brass badge that is riveted on the dome retaining ring is missing. You can still see the Dietz 2-11 engraved in the ring though. 4, the dome is a stratolite. Im sure with some time and cleaning this would be a pretty decent light. Im just a fed sig guy and not interested in keeping it. I have sold these anywhere from 300 -500 in the past in good and original condition. With the issues it has im only asking 150 OBO.
