Dual Color Flash Patterns
theroofable
1,379
New Jersey
Looking for some help with dual color light programming. Im using the cencom carbide with dual color ions and a dual color liberty. I'm not a fan of the no off time between switching colors. For example the off time on a single color light is filled with the flash of the other color. Are there any patterns that give some off time between the colors?
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
Ive never had my hands on ions, but the only pattern I'e ever seen that comes close to that is the ping pong pattern. It's not a very good pattern imo. The only way to get off time is wire them to a flasher that does. And that only works if you have separate trigger wires for each color. I had to do that to my M6s.
theroofable
1,379
New Jersey
Maybe they will add that as an update in the future to the software. Was just wondering if someone had figured out a way. I guess trio patterns aren't possible with the carbide then? There wouldn't be any time for the third color to flash.
got_yogurt
BC, Canada
Some of the CTScan and Duo Scan patterns might be close to that, there’s so many I haven’t sat through them all but it’s worth a look
Caldwell205
