Whelen Edge 9M TA help
I recently picked up a UK contract (Woodway) Edge 9M that I can only assume came off an old fire truck, as it only has corner strobes and nothing else, I’m looking to build it up with TD’s, alleys and front facing halogen flashers.
On the back I want to put a TA in it, but as it’s a 55” bar, it has space for 7 modules and I’m struggling how to set it out without it looking stupid.
I could use 6 400 series heads, but that leaves the centre section blank making it look a bit silly.
I’ve also seen 8 lamp versions that look to use side by side duplex 700 series heads but based on measurements they would leave a gap that wouldn’t fit any blanking module.
Any advice would be appreciated as I’m completely stumped
Hey Mate, In my own opinion. To avoid weird gaps, your best bet on a 55" Whelen Edge is a center-split 6- or 8-lamp setup with a center spacer. Otherwise, just grab the blanking panels made for that frame spacing.
autovet
