Edge question
jdh
Veteran Member
120
Geneva, FL
The whelen site is useless. I can not find this.
I need a wiring diagram for the edge bar model # 2416. Specifically the 94 series edge matrix board.
Thanks
Im not sure. I need a pic of the matrix board. The cable was basically "yanked" out of the bar, so I do not know where the main power (hot and ground)(8 or 10 AWG) cable plugs into the board. :eek: They were nice enough to leave me part of the control cable. :roll:
When I put power to what I think is where it is supose to go...I hear the realys click, but nothing powers on. No strobe, alleys, take downs, flashers etc.......Nothing...except click click click
UPDATE: That is not the diag I need. I believe the one you have is for a hi current switching bar. The control cable does not have a ground. Also I got the halogens to work...and PS I hate bad allagator clips :evil: :oops: . But no strobes and yes I did check the fuse.
OK I get strobes when I power the supply directly. It is an EB-6. In which I am very familure (is there a way we can get spell check here :D )with.
I think I figured it out. Thanks to "bigcat" pictures.
I would realy like to know what the designers at Whelen were smoking when they came up with this one. Why....oh Why do you need to put 2 seperate hot and grounds to the same damn control board. One is to power the strobes and the other for the halogen accessories.
Reminds me (if anyone has worked on fire alarm systems) of the pyrotronics system 3. I would like to know what bong head came up with this idea. Lets mess with all the technicans by having end-of-the-line capacitors instead of resistors. How many mulitmeters do you know that have a cap check? All of them read resistance.
darkdreamer3
