Hoff
I have a question about the wiring to the V-Con from the Excalibur. The bar has four halogens that are connected to two flashers (two lights to a flasher) and they do not turn on. With some investigation, and after replacing the bulbs, it looks like the wires to the flashers/halogens aren't hooked up to the back of the V-Con. Is getting the halogens/flashers to work as simple as finding the same color wire and attaching it to the appropriate spot on the back of the V-Con... say slide position 2?
I'm new to the boards and I realize that it sounds pretty simple. I just wanted someone who knows what they are talking about to confirm my suspisions and give a little guidance on how to fix this problem.
Also while on the topic of the Excalibur, has anyone heard of someone replacing the halogen bulbs in a rotator with LED bulbs? Is it even possible? I don't know if the light output would be any better with a LED bulb than the halogens are already doing. Just trying to think outside the box on how to make the bar better.
NOTE: I can't remove the bar or simply drop some Optix on the lower deck.
