Excalibur project for Ram 2500
smitty711
Senior Member
684
14
49
California
This will be going on a Dodge Ram Pickup. It will have a high box on it once the bed is removed. So lights to the rear of the bar.It's for an EOD vehicle...lightbar is setup as follows Red/clear/Blue and is a mix of Code 3 Ledx and 6up optics.
Driver side Upper: 1 inner ledx and 2 outer dbl stacked ledx
Passenger side lower: 1 ledx side, 1 ledx corner, 2 6 up optics to the front with one on steady burn
Middle upper: Black dome
Middle lower: Optic 33 in clear/clear
passenger side Upper : 1 inner ledx 2 outer dbl stacked ledxurn
passenger side lower: 1ledx side, 1 ledx corner 2 6 up optics to the front with one on steady burn
here is a photo and video links..they were to big to post:
http://www.youtube.com/watch?v=T47WLoNjHSY
http://www.youtube.com/watch?v=B9p0Ij7FaJoAttachments
they will DEFINETELY see ur butt coming.......if they dont have their heads up their ass, or texting, or talking on the phone while driving.
They always do....
Seriously though, nice build.
so, if we buy new domes we are thinking clear...what do you guys think?? shine up the old ones or go with clear...to answer some question i was pmed.....The corner and side ledx in the lower section are on factory flash. the center clear optics 33 were randomly set up and on the first try were synchronized like that and turned out pretty cool....the flashing lower optics and upper ledx are on a show me led flasher.....
My preference is always for domes the same color as light output except when using multiple colors. Maybe replace black center dome with clear and put in a white set of LEDs in front and amber in back?
cory y said:
or.... put a clear upper dome and a oscilazer!
If you're gonna go that direction, use a PowerArc. Similar (greater?) output, the same effect. Do a single white one in front, and a double amber one (in a wide V-shape) in back.
no need for rear lighting in the bar..a box will be mounted to the truck that sits above the roof line by 2ft
M'kay, scratch the amber. Either use a set of stationary white flashing LEDs, or an oscillating PowerArc, in the center, with a clear dome.
BlueOrange
