Factory high beam flasher on Toyota Corolla
Newberry13
SC, USA
I noticed that my 2012 Corolla has a high beam flasher that comes on when the alarm goes off, or the panic button is pressed. My question is this: is it possible to manually activate it without triggering the alarm? I'm planning on doing an install with what I have do far, but would rather have the headlights flash then just a set of HAWs. Thanks in advance!
May 25, 2010
7,072
Tunkhannock, PA, USA
I'm sure its just the BCM flashing the headlights, most factory car alarms do that, but it flashed the headlights together, not alternating...  Just install a HLF on it, shouldn't be too hard...  Its a 9005 bulb, and you could try my "No Splice HLF" method...
Newberry13
SC, USA
That's what I figured. Oh well, does anyone know if high beams are positive or negative switched? I don't have a multimeter, and it'll be next week before I can get my hands on one.
Gasman
