Fed Sig Vision TA
CT-Lighting
73
Bell Co., TX
Have a E-One Hush with a 48" 6 head Edge (4 front/2 rear) and a non-work whelen 8 head TA in the rear. I have a Vision with a TA. I would like to use the Vision I have a Vision but the TA but would be blocked but the "vent/AC' on top the cab. Would it be smart to use remove the TA, put it in the and just run the "cable/wire" to the Vision PC board mounted in the bar?
Any thoughts.
The T/A Should be a separate wire running from the lightbar? I know the Vector's have this, not 100% sure with the visions.
If it is the case, you could just run the wire from the T/A into the cab and hook it up to a controller.
You most certainly can and should separate the TA from the Vision, and mount the TA where it'll be most useful. All you should need is some multi-conductor cable and you're set. Pop the hood on the Vision, and you'll see how easy it is.
GabeP.
