Pat_Hogle
I have a 52" Federal Signal S1B-L Street Hawk. 52 Inch with speaker enclosure. No speaker. All Amber. Is fully functional and was in use until February when removed from vehicle. 2 clear lower lenses with the remaining lenses in amber. All lower level bulbs have been swapped for LED replacements (4 amber, 2 white under amber lenses).
Bar is in good shape and could be put into use. However as you can see in the photos, it could also benefit from a serious cleaning. Domes are hazy and have some rub marks but no cracks. One corner screw was had been replaced at the time I acquired the bar. Frame base needs a good cleaning due to surface corrosion but is solid. The mounting feet are not correct. They are Code3 mounting feet modified to fit.
Original wire harness is also gone. Currently has a 4 wire set up as at one point I had it set up with rotators, rear/side flashers and front take-down lights. Currently set up for lower level as all flashing.
Shipping will be from 14608. Asking $200.00 plus shipping, though I am open to reasonable offers.
