RebelLiners Member Member Jan 28, 2012 205 Attica NY Jan 31, 2012 #1 can you use any light bar or light set up with a FEDERAL SIGNAL VISION LIGHTBAR CONTROLLER SYSTEM KEYPAD BRAIN INTERFACE SYSTEM? ?
EL1998P71 Senior Member Member May 23, 2010 704 Sterling Heights Mich Jan 31, 2012 #2 You have to use a federal vision brain and vision keypad. Unless you are savy enough to figure out how to bypass the circuit board in the bar. Getting a fedsig brain amp and keypad would be alot easier.
9 911 Forum Guru New Member May 22, 2010 3,833 New York City Jan 31, 2012 #3 the correct answer would be, the vision system is for the vision bar, you cannot hook up any lightbar or lights to it...... it needs to interface with the vision bar with the correct chip set and revisions..........
