Federal Signalmaster LED traffic amber light??
Hoser
Passed Away
3,704
Ohio
I just got a FS Signalmaster LED 3ft Traffic amber light. Do I need the FS Controller or will one of the others such as a Code 3 controller work? Thanks in advance. Also if anyone has one they want to part with give me a PM. Thanks Hoser
Hoser said:
I just got a FS Signalmaster LED 3ft Traffic advisor. Do I need the FS Controller or will one of the others such as a Code 3 controller work? Thanks in advance. Also if anyone has one they want to part with give me a PM. Thanks Hoser
traffic advisor? do you mean signalmaster? just curious.....
Hoser said:
Ok its a Federal Signal 328000 OHP Series A. Also looking for wiring diagram as the connector has been cut off at the plug, possibly when they removed them from service.
that is a 33 inch low profile cuda led signalmaster. should work with most other controllers as long as they are negative switched. I do have an extra Federal Signal controller, NOS.
It will work with any other negative switched controller. Mine is currently hooked up to a Whelen TACTLD1 because it has better patterns than the stock FedSig SignalMaster controller.
Hey I have a fed sig traffic advisor and the whelen TACTLD1 control head, do you know the wiring crossover for this control head to my lights? thanks
fpd 317
