Feniex Cannon steady burn white light output in Lumens
Below is an Email response I received direct from Feniex. The only information redacted from the letter was the name of the Customer Support representative.
I hope some of my fellow ELB members find the following information helpful.
"Adam,
Thank you for your inquiry, the Cannons can be run on a steady burn pattern for extended periods of time, although they will only steady burn 6 LED's they will not steady burn all 12 for both single and dual colored Cannons. The Cannon 360 has an alternate lens which produces more light 360 degrees around the sides of the lens, which is designed for mounting in a fog/reverse light housings. As for the Lumen count, one white LED is 180 Lumens, so for 6 LEDs on the lumen count would be 1,080 Lumens.
If you have any other questions, please feel free to contact us by calling our support line or by e-mailing us."
Sincerely,
1-800-615-8350
Customer Support
Feniex Industries, Inc.
Support@Feniex.com
www.Feniex.com
Reactions: Bogie
KI_CopCar
