cabunty
I have bought a barely used Feniex Fusion Pass side ILB. I thought there was takedown functionality/all modes steady burn but it does not have this. Is there a way to make this work or is it a no go because it was not spec'd with it from the factory? The PCB says "Rev 08.
If not, second question, will a Fusion 2X single color dash light run four modules?
Thank you!
Thank you!
