Station 3 said:Looks very slick i like it.
jonny521 said:does it get really hot?? just wondering cause theres a thread on a feniex product and they said it gets hot??
jonny521 said:nice looking setup. does it get really hot?? just wondering cause theres a thread on a feniex product and they said it gets hot??
TraFx said:The brackets needed a tad bit of an adjustment (bend upwards) on the interior visor mounts but other than that no issues.
niiice ok let us know the results of itFast LT1 said:Alex at Feniex is sending me some of their hide-aways to test, i will look for heat problems, and sync problems, i will also put them one of Pimp's torture test's.
jonny521 said:niiice ok let us know the results of it![]()
Feniex said:TraFx, love the install. Regarding your comment about bending the brackets I don't recommend you do that. Use the height adjuster plate to decrease the gap between the headliner and the lightbar. The rubber edge trim provided will do the rest. Depending on the year make and model of your vehicle the height adjuster plate may or may not be needed.
Looking forward to your video
zach3713 said:Can't wait for the video, i'm contemplating getting one, but really want to see all the flash patterns first. Looks sharp though!
zach3713 said:One question, are all the bars the same specs, and the brackets different for the vehicle, or are all the bars shaped differently for different cars?
Kevin K. said:Not a bad interior lightbar at all. Do you have any preliminary info about the Avatar? I believe that's supposed to be the roof-mounted bar that's forthcoming sometime during this quarter. I'm curious to know if the Avatar has any resemblance to any SoundOff lightbars, seeing that it appears to me that a number of SoundOff engineers defected to Feniex.
Alovebaby41 said:By using all TRI modules how is the off-axis? That is my concern.
OverLordOfYou said:I'm placing my order soon but have a question. On the wiring diagram it implies to have the brown wire to the bateery and have the red on a switch bc if you do it the otherway around it defaults to random instead of recall memory. Was this the case on your installation?opcorn:
Marc M said:What are the other lights used on the car?
TraFx said:Fantastic install! Two questions, sir.
1. Have you heard any more info on the avatar bar? I'm with a volunteer FD and the majority of our vehicles still have the old nasty rotator gumball machines on them and I would love to see some of the Feniex products go on top.
Bigredinstalls said:I have not heard anything else from them on the Avatar in a while. I will check and see if there is any update on a release date, etc.
2. Being with the volunteer FD we are allowed to respond with blue lights but not white, however I still want to have takedowns on my vehicle for if I have to stop at night or whatever the reason be that I need additional forward lighting. Is it possible to get the lights flashing to the front in the same setup as you have say
bbbtbbtbbbb or bbtbttbtbb or anything like that to have the blues flashing but the with the takedown lights off? Or is there a way to set them to flash, steady, or off? Or what are the takedown options?
Let me check with them and see. They may be able to set it up in that configuration for you. I will shoot you a PM when I find out.
