Is the pin out still the same? Can’t find much info online for the 4Yes, it definitely does.
Was anyone able to figure out how to get ithe amplified charger to reset automatically? For example, when our tones go off, the pager goes off twice within about 20-30 seconds depending on the dispatcher. From my testing, the lights only go off the first time and will not go off again unless the amplified charger is reset
Pins 4 and 5 of the accessory connector are used to select the time duration of the relay contact closure. If these two pins are NOT used (open circuit), the relay will remain energized for approximately 10 seconds after an alert is received. If pins 4 & 5 are SHORTED, the relay will remain energized until the 'RESET' button on the front of the charger/amplifier is depressed. Pressing the 'RESET' button causes the contacts to open and turns off the ALERT indicator."
I pulled the system out of service and I was using pin 4 (white cable) and the shield. The system works but has to be reset manually, do you know which pins i need to use?You're probably experiencing this because pins 4 and 5 are connected. Try breaking that circuit.
Would I use pin 5 as the trigger for the relay?With pins 4 and 5 connected, you're setting your relay to require manual reset. Disconnect pin 4 from pin 5 to set your relay for automatic reset.
I am not going to lie, I am kind of lost now, I'm probably over thinking about this. I am using the amplified charger to trip the Altronix 6062 board. I was originally using the white cable (pin 4) as the trip and the shield as the ground.The relay we're talking about is internal to the amplified charger base.
so we had the company who installed the system here today and they think the delay is that the system needs to be 24v or the problem is in the horn strobes and may have to swap them out for different ones. Does that sound right?
Do you have a wiring diagram for this? And list of parts
This is what I put together. This uses two-tone detect that sends a trigger to a MQTT broker then node-red gets the trigger. From node-red the possibilities are endless. I have it also turn on my bedroom/hallway/garage lights between dusk and dawn with a 2min timmer to turn off.
The sounds is coming over a Sonos speaker and using a Wemo switch a generic 12v 5a power supply.
