I have a 2010 Chevy Avalanche and was looking to install a Flashback system. The rear light setup is similar to many of the new model Tahoe's and Suburban's with a upper and lower tail/brake light and a reverse light in the middle. The upper and lower tail/brake light come on when the brake is pushed, and both flash when the turn signal is used.
I have noticed that most of the Chevy vehicle with Flashback systems only flash one set (either upper or lower) of the tail/brake light and reverse light. I want to flash all 4 brake/tail lights against the 2 white reverse lights.
(I am trying to stay away from 6 hideway LEDs because of budget concerns.)
On a second thought... if I replaced all the standard bulbs with LED replacement bulbs, could I use a standard LED flasher?
Has anyone done that? Or are you able to only flash one set of red's against the reverse lights? Any thoughts or comments would be appreciated. Thanks
