Flasher for fusion ILB
needforspeed
145
Massachusetts
Specifically I was told that the Fusion dummy heads can be controlled by;
Constant +12V to red wire
Constant ground to black wire
+12V to trigger wire for steady, or pulse +12V for flashing at pulse rate
Do I understand this correctly?
FusionWolf
504
Massachusetts
If they use dummy heads (2wire) then yes you can use an external flasher. You have to rewire the bar. But I made a custom bar for my Xterra using dummy heads and hooking it up to CanTrol. Works flawlessly and allows sync to other lights
needforspeed
145
Massachusetts
So the answer is yes as described above. The three wire modules I have work fine with a separate positive flasher. I'm going to use a ULF-44 to get the patterns and sync that I want.
woobatu
