hutch
I have a couple of questions while planning out 3 Interceptor Utility installs I will be doing soon. These are the first ones I have worked on.
Do you have any photos of where you are drilling into the firewall? I would like to drill on the driver's side. I don't like Ford's location on the passenger's side.
I will be adding the following equipment to the rear of the vehicle:
Ultra lite (8 head) to the rear window, LED 3s to on a LP bracket and two recessed ghosts on the bottom of the tailgate. I would like to wire it so the ultra lite and the LED 3s shut off and the ghost turn on when you open up the hatch. I believe that these vehicles come with a "hot" wire that is trigged when the hatch is open? If so can I just use two relays to accomplish this? If so what pins do I use on the relays?
Thank you for your time!
Alex
Alex
