FS Solarias ILS
cybercop
302
14
USA, TX/South
I have the above mentioned lights in my brand new unit. How do you change the pattern on those things? I absoulely hate the current patterns in both the front and rear.
I would also like to have it to where the white takedowns dont flash when i'm in mode 2 (mode 1 is rear only, mode 2 adds fronts, mode 3 adds siren) because the white LED take downs drowns out the red/blues (very overpowering).
Thanks.
What's it being controlled by?
If it's a Smart Siren Platinum, you'll have to reprogram the controller.
If it's some other standard-switching controller, you'll have to adjust the serial interface's programming.
As much as I LOVE the ILS systems, changing the patterns are a PIA! It involves locating the serial interface box, putting power to the pattern wire, then power to the "position" you want to change, then pushing the little white button, then removing power and then repeating for each "position". Thats the only major issues with the system, unless you have access to a dealer that hase the computer programmer for the interface.
jdarland
