Jamey@NNE
Always fuse 18in from battery no matter what. What if it shorts before your controler? Fire.... Nothing stopping it.
mhchockey84 said:negative the controller instructions did not specify any fuses necessary
mhchockey84 said:Marked where the fuses are
CORRECTION TO MY PAINT POST THE INLINE FUSE IS IN THE VEHICLE AFTER THE WIRE PASSES THROUGH THE FIRE WALL
and i will post wiring pictures once i get home and the rain slows down
bigcat said:Why would the fuse blow with the controller off? Even if a wire was pinched, the fuse shouldn't blow until the output on the controller is activated. From this information I would question a problem with the controller output.
To test the wiring to the LINz6s and vertex, simply bypass the controller. Put a 5 amp fuse inline and hook the circuit wire up to the positive wire on a cigar plug INSTEAD OF the output on the controller. If you plug in the cigar plug and the fuse blows, then you're wiring needs to be redone on that circuit. If it works, then it is a controller issue.
You could also attach another circuit to the controller output in question and see if the fuse for that blows. If you trust your talon wiring, you could use that circuit or wire something up quick. I have little marker lights that I keep around for testing flashers and such. If I fry one, its no big deal. Just wire up one light with an inline fuse and ground it somewhere to the car. Then connect it to the output and see what the fuse does.
