Abacus
I am just checking that if I am installing a fused relay ( ie one thats got an inbuilt 15 amp replaceable blade fuse) , I dont need to install a separate fuse between the battery and the fused relay. There will only be at most 6 inches between the battery and the fused relay.
The fused relay going to power an external power socket at the rear of the truck bed and switched from inside the truck cabin
Thanks in advance
Thanks in advance
