I have done some looking and seen some info on other models external flasher capabilities, but I wanted to check and see if the feniex fusion surface mounts can be used with an external flasher effectively.
I had done an install with some apollo surface mounts a couple years ago and had to use the slowest single flash pattern to even get them to illuminate properly with the external flasher we were using and just wanted to make sure I wasn't going to run into the same thing this install.
Thank you.
Thank you.
