Havis custom cutting
grfd711
1,546
Sherwood, AR
I'm going to install a Motorola MCS2000 pretty soon. Looked on Havis' website for the one piece bracket and it's 3" in clearance. The blank filler panel I've got is 2 1/2". I don't want to buy a whole new console, so it's going to be one of two things:
1) Trim down one or two brackets to make everything fit
2) Buy an under dash mount for the control head and most likely mount it to the filler panel.
I'd prefer option #1, so curious if anybody has been in my situation before and if you've cut the brackets before. If so, how easy or hard was it?
kool aid 960
111
Nassau County NY
Ive grinded down a havis switch panel before to custom fit it in my jotto desk console. I didnt have to grind it down much but from what I remember it wasnt to terribly difficult I just went real slow and check every few passes for a fit
rwo978
ND, USA
Is there a 2 piece option? That cuts the top and bottom half off and about 1/2 inch.
TCO
Malvern,Pa
there is some stuff available that is not always on the website. The main sales location/installation center is near my work in Warminster. try to give them a call directly to see if they can help you.. ask for Dave 215-957-0720
Tom
TCO
Malvern,Pa
if you do not want to make the long distance call,send me a pm with exactly what you are looking for with dimensions if it is any different from your first post. i will be stopping there for parts tommorrow and will get the info you need.
Tom
grfd711
1,546
Sherwood, AR
I can call in a lil bit, but what I need is this specific bracket, but a half inch shorter. If you can talk to them in person, feel free to holler at 'em and see if something custom is available.
May 24, 2010
1,627
PG County, MD
I presume this is for a remote mount head? If so, the two piece bracket mentioned above will not work. And I do not believe there is enough material on the top and bottom of the one piece bracket to grind down.
Only option would be to get the one piece bracket and cut it up to make a two piece bracket of your own.
TCO
Malvern,Pa
Part #: C-EB25-MPM-1P is 1 part # i was given that they said would require min modification but may work for your application.. otherwise check you pm
Tom
grfd711
1,546
Sherwood, AR
Did some more looking around, and figured I'd order the Moto Radius M1225 two piece to replace my one piece, which will take off a 1/2". So, have to order the C-EB20-100, which will be my two piece for the M1225 Radius and then the bracket for the MCS200 model III faceplate. Just hate to spend all the money for such a small modification, but at least things will look good.
Kbellinger01
