Help adjusting Edge Freedom TA pattern
John Smith
304
CO, US
Hey all,
I've got a Whelen Edge Freedom LED bar controlled with CenCom Gold. I can't figure out how to adjust the flash/sequence patterns for the traffic adviser. It is not done via the Scan Lock wire.
Any help? Thanks!
got_yogurt
BC, Canada
It would depend on whether the freedom TA is powered by the internal IO board (two wire control), or externally from the cencom (7/9 wire control). If it’s two wire using scan lock when the TA is on will change it. If it’s external you have to use the cencom gold computer program to change it
John Smith
304
CO, US
Thank you, in that case it's controlled via the CenCom controller. I should be getting the USB cable this week so I'll take care of that then. Thank you!
Jhaberny
