So I'm needing to install a battery charger/maintainer on the fire dept's suburban, but I'm running into some mounting problems. I've concluded that no matter where I mount it, I'm going to have to fab an extension plug to reach outside of the engine compartment, but I'm at a loss as to where/how to place it. Pictures are below.
The charger is designed to be mounted inside an engine compartment, so I'm not too concerned with heat issues. I was thinking of mounting it on the inner fender next to the battery, since that's the only place I can find that is solid and empty that it will fit and the wires will reach. Only problem then is where and how to run the cord so it is easily accessible from the outside without having the hood open and doesn't look like crap.
Suggestions?
Suggestions?
