Going on a 2006 C4500. Whelen had no clue on compatibility. Chevrolet could only tell me they didn't go to computerized headlights on medium duty trucks until 2007, so this should be standard switching.
Made connections right behind each housing, used passenger side near jblock. Dropped vehicle wire on drivers side (yellow side of flasher.) Blue side of flasher is connected to green high beam lead vehicle side and that side high beam lamp per diagram on flasher.
All normal headlight functions work normally like this with no main power to flasher. Can activate relays with no ill effects noted. Upon applying power, these occur:
1) all headlights off - wigwag functions normally, but does whine-whine instead of click-click. HBs work as expected, but this noise is not normal.
2) flasher cuts out as expected upon turning on the HBs, except it also cuts out for the low beams.
3) disconnecting either lamp causes the other side to flash, with normal relay click, except it flashes BOTH high and low beam on the connected side. Seems like voltage is getting across something.
Stumped. :Banghead: :Banghead:
